FTo engine detail
การสนทนาใน 'GTO & FTO Sport Cars' เริ่มโดย baskat0007, 6 สิงหาคม 2007
  1. baskat0007
    baskat0007 New Member Moderator
    322
    V6 24-valve MIVEC Engine
    The sophisticated, powerful ([email protected]) 2.0-litre V6 MIVEC (Mitsubishi Innovative Valve timing and lift Electronic Control) DOHC engine switches automatically between two sets of cam lobes: one for deft low rev response with muscular yet controlled torque, and the other for execptional top-end power. The result is a silky smooth ride at steady speeds, with a resonant, throaty bass roar that thrills the spirit when you decide to put the throttle down.
    V6 24-valve Engine
    The powerful 2.0-litre V6 DOHC engine is almost as powerful as it's sophisticated MIVEC counterpart, with flexible torque and outstanding peak power of 180BHP at 7000rpm (a mere 500rpm lower than the MIVEC unit). The result is a more refined engine note at high are RPM with minimal loss in performance. Like the MIVEC engine the 2.0-litre V6 DOHC engine is most at home at high revs.
  2. baskat0007
    322
    อันแรกเป้นตัว mivec ส่วนอันสองนี่ ธรรมดาครับ
  3. baskat0007
    322
    Dimensions
    Front Track
    1490 mm
    Overall Width
    1735 mm
    Wheel Base
    2500 mm
    Overall Length
    4365 mm
    Ground Clearnace (unladen)
    150 mm
    Overall Height (unladen)
    1300 mm (1350 mm)*
    Rear Track
    1485 mm
    * with Sunroof
    Performance
    Type
    Mitsubishi E-DE2A
    Mitsubishi E-DE3A
    1800 16V
    V6 2000 24V
    V6 2000 24V Mivec
    GS
    GR / GX
    GPX / GP Version R
    Max Speed
    125mph
    136mph
    142mph
    Max Power
    125 BHP @ 6000 rpm
    180 BHP @ 7000
    200 BHP @ 7500
    Max Torque
    16.5kgf/m @ 4500 rpm
    19.5kgf/[email protected] rpm
    20.4kgf/m @ 6000 rpm
    Min Turning Radius
    5300mm
    Engine
    Type
    Mitsubishi E-DE2A
    Mitsubishi E-DE3A
    1800 16V
    V6 2000 24V
    V6 2000 24V Mivec
    GS
    GR / GX
    GPX / GP Version R
    Engine Type
    4G93
    6A12
    Valve System and Number of Cylinders
    SOHC 16 Valve 4 Cylinders
    DOHC 24 Valve 6 Cylinders
    Size (mm)
    81.0 x 89.0
    78.4 x 69.0
    Total Displacement
    1834 cc
    1998 cc
    Compression Ratio
    9.5
    10.00
    Weights
    Type
    Mitsubishi E-DE2A
    Mitsubishi E-DE3A
    1800 16V
    V6 2000 24V
    V6 2000 24V Mivec
    GS
    GR / GX
    GPX / GP Version R
    Kerb Weight
    1100 kg
    1150 kg
    1190 / 1210 kg
    Seating Capacity
    4 persons
