HOTROD THAILAND 2011
การสนทนาใน 'Drag Racing' เริ่มโดย ballzwa, 22 สิงหาคม 2011
  1. ballzwa
    ballzwa New Member Member
    ????觢ѹ ö¹?? ?ҧ?ç 402 ???? ʹ?? BANGKOK DRAG AVENUE
    ?ѹ??????? 22 ???Ҥ? 2554
    ??????觢ѹ????????? 10.00 - 02.00 ? ?繡???? ?ѹ???ǹФ?Ѻ
    ?ͺ??? ??? ??Ѥ? ???? 0811014334 ??Ť?Ѻ
    **?Ѿവ??蹡???觢ѹ?Ф?Ѻ **
    ??蹷???Դ????觢ѹ
    ??? super 2000 CC.
    ??? 4 ??? 2??ع???????ش?( Hot 4 and 2 Rotor Pro N/A )
    ??? 4 ??? 2 ??ع ??????? ( Super Street 4 & 2 Rotor )
    ??? 4 ??? 2??ع ?ش? ( Hot 4 and 2 Rotor Pro )
    ??? 6 ??? 3 ??ع ??????? ( Super Street 6 & 3 Rotor RADIAL)
    ??? 6 ??? 3 ??ع ??????? ( Super Street 6 & 3 Rotor RADIAL SPECIAL )
    ??? 275 SPECIAL
    ??? RB ENGINE
    ??? SUPER STANDART ( ?? Header ????Դ?ç?ҹ )
    ??? 6??? 3 ??ع ????????ҹ ( Hot 6 and 3 Rotor Pro )
    ??? PRO Automatic
    㹡ó? ö??Ѥ?????Թ 8 ?ѹ ???蹡???觢ѹ ?ҧ????ҹ???Ѵ?ͻ?Ъ????͹????觢ѹ?Ф?Ѻ
    ??ԡҢͧ??????蹹ФѺ
    (Technical Regulation )
    1. ??? 4 ??? 2 ??ع ??????? ( Super Street 4 & 2 Rotor )
    ??Ƕѧö????ʫ?
    - ??ͧ??ö¹?????ը?˹??·???仵????ͧ??Ҵ ?Ѻ????͹ 2 ???? 4 ??? ???Ե?????ͧö
    - ͹حҵ???????¹?ҡ???ç˹??,??ѧ , ?ѧ?Ź˹?? ?繾??ʵԡ??????????????
    - ???͹حҵ???????¹??Ш??ͺ?ѹ?繾??ʵԡ?˹??? (Poly Carbonate )
    - ??еٷء?ҹ??ͧ????ö?Դ?ҡ??ҹ?͡-???
    - ?ԵԢͧö??ͧ???????¹?ŧ仨ҡ???
    - ?ʫմ?ҹ˹????? Fire Wall ??ͧ?繢ͧ???
    - ?к???Ѻ?ҡ?ȵ?ͧ?ӧҹ??????????е?ͧ?դ??????
    - ?ػ?ó?????ö??ͧ?դú????ҵðҹ?ҡ?ç?ҹ
    - ?óշ???? Roll Cage ????ö ͹???????????ͧ???????ѧ
    ??ǧ??ҧ
    - ??ǧ??ҧ˹???????ѧ??ͧ?繨ش?ִ??????Ẻ??? ??͹حҵ???Up Grade ?ػ?ó???
    ????ͧ¹??
    - ??ͧ??????ͧ¹?? 4 ?ٺ???? 2 Rotor ??ҹ?? ???ӡѴ???Modify
    - ???ӡѴ?к??Ѵ?ҡ??
    - ???͹حҵ?к? Nitrous Oxide ( ???????ػ?ó???Դö)
    - ??ҹ˹???ش?ͧ????ͧ¹???ͧ???????Թ???ҡ?觡?ҧ?ͧ??????˹???????????????㹼?ѧ
    - ?????ʹ??¾ҹ?????͡
    - ???????????¹?????????к? Air Shifter ?ѹ??????ͧ??Ẻ H-Pattern ??ҹ??
    - ????? Automatic ??ͧ????????????ҹ??
    ??????ԧ
    - ͹حҵ?????੾?? ????ѹ Gasoline ( ???ӡѴ??? Octane ) ??ҹ??
    - ?Ѻ????͹?????ѧ ͹حҵ?ҧ DRAG Radial ???? ͹حҵ?ҧ Radial (??????) ?ء??Դ ??? treadwear ????ӡ??? 140
    - ö?Ѻ????͹???˹????? ͹حҵ?ҧ?ء??Դ
    - ö?Ѻ 4 ??? - ͹حҵ?ҧ Radial (??????) ?ء??Դ ??? treadwear ????ӡ??? 140 ??Ҵ????Թ 235 mm.
    ???˹ѡö
    - ö¹?? 4 ?ٺ ?Ѻ????͹???˹?? ??ͧ????ӡ??? 1,000 Kg ??????Ѻ
    - ö¹?? 4 ?ٺ ?Ѻ????͹ ?????ѧ ??ͧ????ӡ??? 1,100 Kg ??????Ѻ
    - ö¹?? 4 ?ٺ ?Ѻ????͹4 ??? ??ͧ????ӡ??? 1,200 Kg ??????Ѻ
    2. ??? 6 ??? 3 ??ع ??????? ( Super Street 6 & 3 Rotor RADIAL)
    ??Ƕѧö????ʫ?
    - ͹حҵ???????¹?ҡ???ç˹??,??ѧ,?ѧ?Ź ?繾??ʵԡ??????????????
    - ?к???Ѻ?ҡ?ȵ?ͧ?ӧҹ??????????е?ͧ?դ???????ػ?ó?????ö??ͧ?դú????ҵðҹ?ҡ?ç?ҹ
    ??ǧ??ҧ
    ????ͧ¹??
    - ??ͧ??????ͧ¹?? 6 ?ٺ???? 3 Rotor ??ҹ?? ???ӡѴ???Modify
    - ???ӡѴ?к??Ѵ?ҡ??
    - ?????ʹ??¾ҹ?????͡
    - ???????????¹?????????к? Air Shifter ??? ????? Automatic
    - ?ѹ??????ͧ?繸?????Ẻ H-Pattern ??ҹ??
    ??????ԧ
    - ?ҧSeries ????Թ 275 mm
    - ???·?͵?ͧ?ѹ?͡?͡?ǵ?Ƕѧ?ҧ??ҹ??ҧ??д?ҹ??ѧ ????????????ŧ??????ҧ?索Ҵ
    ?????٧?ͧ????????µ?ͧ????ӡ??? 3? ?Ѵ?????٧?ҡ??鹶??
    ???˹ѡö
    - ????ӡ??? 1,300 Kg ??????Ѻ
    3. ??? 4 ??? 2??ع???????ش?( Hot 4 and 2 Rotor Pro N/A )
    ??Ƕѧö????ʫ?
    - ͹حҵ???????¹?????ǹ???͵??ö?繾??ʵԡ??????????????
    - ????Ѻö Volksawagen ??ͧ?? Floor Pan ?????ҹ??
    - ͹حҵ???????¹??Ш??ͺ?ѹ?繾??ʵԡ?˹????? ( Poly Carbonate )
    - ??еٺҹ˹?ҷ???ͧ??ҧ??ͧ????ö?Դ?ҡ??ҹ?͡-???
    - ?ʫմ?ҹ˹????? Fire Wall ??ͧ?繢ͧ??????͵??˹???? ( ????ö?Ѵ???? )
    - Floor Pan ( ?????ҧ ) ?ҡ??ҹ˹?ҵ?ͧ????Ҿ??????֧???˹觵ç?Ѻ?ͺ??ҹ??ѧ?ͧ?õ?
    - ?ʫդ?????ѧ????ö???????¹?ŧ?????ӡѴ ???ͧ??????觤??????ç?ͧ?ʫ?ö
    ( ????㹴?žԹԨ?ͧ??????õ?Ǩ??Ҿ??й??ʹ??)
    ??ǧ??ҧ
    - ??ǧ??ҧ˹?ҵ?ͧ?繨ش?ִ????Դö ??͹حҵ???Up Grade ?ػ?ó???
    - ??ǧ??ҧ??ѧ͹حҵ??鵡???????ӡѴ
    ????ͧ¹??
    - ?????к??к??Ѵ?ҡ??
    - ????? Automatic ??ͧ????????????????????ҹ?? ??е?ͧ?? Torque-converter ??? Planetary Gearsets
    ??????ԧ
    - ͹حҵ?????੾?? ????ѹGasoline (???ӡѴ??? Octane ) ??? ??š????? ??ҹ??
    - ö?Ѻ????͹???˹?? ͹حҵ??????ҧ Drag Slick ???????ҧ????Թ28?x 10.5??????ҧ Radial ???ӡѴ??Ҵ ??駹???ͧ??????͡?ҹ͡?ѧ?Ź˹???Թ 2?( ????ö??Over Fender???????? )
    - ???˹?????ӡѴ??Ҵ ????Ѻö?Ѻ2?????ѧ
    - ?????ѧ Drag Slick ????Թ 28?x 10.5????? ?ҧ????? DOT ????Թ 28? x 13.5?????ҧSeries ????Թ 335mm.
    - ö?Ѻ 4 ??? ??????ҧ Drag Radial ??Ҵ????Թ 225mm. ???ӡѴ?????? ????Drag slick ????Թ 26?x 8?
    - ??Ҵ?ͧ?ҧ?ִ??͵??????Ţ?͡??Ҵ????ҡ???????ҧ
    ???˹ѡö
    - ????ӡ??? 700 Kg ??????Ѻ
    - ** ö??? ?????˹ѡ????ӡ??? 650 ???š??? ** (???й??˹ѡ????ҡ?ç?ҹ???֧ 750???š???)
    4. ??? RB ENGINE
    ??Ƕѧö????ʫ?
    ??ǧ??ҧ
    ????ͧ¹??
    - ??ͧ??????ͧ¹?? RB ENGINE ??ҹ?? ???ӡѴ???Modify
    - ?????ʹ??¾ҹ?????͡
    ??????ԧ
    - ͹حҵ?ҧ Radial (??????) ?ء??Դ * ???????к????˹???ش???¢ͧ??ԡ? *
    ???˹ѡö
    5. ??? SUPER STANDART ( ?? Header ????Դ?ç?ҹ )
    ??Ƕѧö????ʫ?
    ??ǧ??ҧ
    ????ͧ¹??
    - ???ӡѴ????ͧ¹?? ??ͧ??Header ??????Դ?ҡѺ????ͧ ??ҹ??
    - ͹حҵ????ࡵ?¡??
    - ?????ʹ??¾ҹ?????͡
    - ?ѹ??????ͧ?繸?????Ẻ H-Pattern ??ҹ??????? Automatic ??ͧ????????????????????ҹ?? ??е?ͧ?? Torque-converter ??? Planetary Gearsets
    ??????ԧ
    ???˹ѡö
    6. . 6 ??? 3 ??ع ??͹??͹???? (Pro Special 275 )
    ??Ƕѧö????ʫ?
    - ͹حҵ???????¹?????ǹ ?? ?ҡ???ç,?ѧ?Ź,??е? ?繾??ʵԡ??????????????
    - Floor Pan ( ?????ҧ ) ????ҡ?ç?ҹ
    ??ǧ??ҧ
    - ??ǧ??ҧ ˹??-??ѧ ??ͧ?繨ش?ִ????Դö ??͹حҵ???Up Grade ???????????ػ?ó???
    ????ͧ¹??
    - ??ͧ??????ͧ¹??????Թ 6 ?ٺ???? 3 Rotor ??ҹ?? ???ӡѴ???Modify
    - ???ӡѴ?к??Ѵ?ҡ??
    ??????ԧ
    - ͹حҵ?????੾?? ????ѹ Gasoline ( ???ӡѴ??? Octane ) ??? ??š????? ??ҹ??
    - ?ҧSeries ????Թ 275mm.???ӡѴ?????ͧ͢?ҧ
    - ö?Ѻ 4 ??? ??????ҧ ??Ҵ????Թ 255mm.
    ???˹ѡö - ????ӡ??? 1,250 Kg ??????Ѻ
    7. Pro automatic & Air Shifter
    ??Ƕѧö????ʫ?
    - Floor Pan ( ?????ҧ ) ?ҡ??ҹ˹?ҵ?ͧ????Ҿ??????֧???˹觵ç?Ѻ?ͺ??ҹ??ѧ?ͧ??е٤??˹??
    ( Door Trailing Edge ) ??????????????䢴Ѵ?ŧ?????ͧ?բͺ?ͧ????ҡ???????٧????? 3?
    ?????ҧ????
    ??ǧ??ҧ
    ????ͧ¹??
    - ????ͧ¹?? 4 - 6 - 8 ?ٺ???? 2- 3- 4 Rotor ???ӡѴ???Modify
    - ???ӡѴ?к??Ѵ?ҡ??
    - ͹حҵ?к? Nitrous Oxide
    - ????¹?????????к? Air Shifter, Automatic , Manual
    - ͹حҵö???????????Manual ????դѹ?????????㹡??????¹??????ҡ???? 1 ?ѹ?????
    ??????ԧ
    - ͹حҵ??????ҧ Drag Slick ???????ҧ????Թ 32?x 12??????ҧ Dot ???????ҧ????Թ 32?x 14.5?
    ???˹ѡö
    - ö¹?? 4 ?ٺ ???? 2 ?????? ??ͧ????ӡ??? 900 Kg ??????Ѻ
    - ö¹?? 6 ?ٺ ???? 3 ?????? ??ͧ????ӡ??? 1,250 Kg ??????Ѻ
    - ö¹?? 8 ?ٺ ???? 4 ?????? ??ͧ????ӡ??? 1,350 Kg ??????Ѻ
    8. ??? 6??? 3 ??ع ????????ҹ ( Hot 6 and 3 Rotor Pro )
    ??Ƕѧö????ʫ?
    - Floor Pan ( ?????ҧ ) ?ҡ??ҹ˹?ҵ?ͧ????Ҿ??????֧???˹觵ç?Ѻ?ͺ??ҹ??ѧ?ͧ??е?
    ???˹?? ( Door Trailing Edge ) ??????????????䢴Ѵ?ŧ?????ͧ?բͺ?ͧ????ҡ??????
    ?٧????? 3? ?????ҧ????
    ??ǧ??ҧ
    ????ͧ¹??
    - ???ӡѴ?к??Ѵ?ҡ??
    - ????? Manual ??ͧ????¹????? ???´???????????? ??? ??Ẻ H- Pattern ??ҹ??
    - ????? Automatic ??ͧ????????????????????ҹ????е?ͧ??Torque-converter ???
    Planetary Gearsets
    ??????ԧ
    - ö?Ѻ????͹???˹?? ͹حҵ??????ҧ Drag Slick ???????ҧ????Թ 28?x10.5??????ҧ Radial ???ӡѴ??Ҵ
    - ö?Ѻ 4 ??? ??????ҧ Drag Radial ??Ҵ????Թ 275mm.???ӡѴ?????? ????Drag slick ????Թ 26?x8???? ?ҧ????? DOT ????Թ 28? x 10.5?
    ???˹ѡö - ????ӡ??? 1,100 Kg ??????Ѻ
    9. ??? 6 ??? 3 ??ع ??????? ( Super Street 6 & 3 Rotor RADIAL SPECIAL )
    ??Ƕѧö????ʫ?
    ??ǧ??ҧ
    ????ͧ¹??
    - ???ӡѴ?к??Ѵ?ҡ??
    - ?????ʹ??¾ҹ?????͡
    - ?ѹ??????ͧ??Ẻ H-Pattern ??ҹ??
    - ?к? Trip Tronic ??ͧ?Ҩҡ?ç?ҹ?Ǻ????ҡѺö????????ҹ??
    ??????ԧ
    - ö?Ѻ????͹???˹?? ͹حҵ??????ҧ Radial ??Ҵ????Թ 275 mm
    - ?????ѧ?ҧSeries ????Թ 275 mm .
    ???˹ѡö
    10. ??? 4 ??? 2??ع ?ش? ( Hot 4 and 2 Rotor Pro )
    ??Ƕѧö????ʫ?
    ??ǧ??ҧ
    ????ͧ¹??
    - ???ӡѴ?к??Ѵ?ҡ??
    ??????ԧ
    - ö?Ѻ????͹???˹?? ͹حҵ??????ҧ Drag Slick ???????ҧ????Թ28?x 11.5??????ҧ Radial ???ӡѴ??Ҵ
    - ?????ѧ Drag Slick ????Թ 28?x 11.5????? ?ҧ????? DOT ????Թ 28? x 13.5?????ҧSeries ????Թ 335mm.??駹???ͧ??????͡?ҹ͡?ѧ?Ź?Թ 2?( ????ö??Over Fender ???????? )
    - ö?Ѻ 4 ??? ??????ҧ Drag Radial ??Ҵ????Թ 255mm. ???ӡѴ?????? ????Drag slick ????Թ 26?x 8? ??? ?ҧ????? DOT ????Թ 28? x 10.5?
    ???˹ѡö
    แก้ไขล่าสุดโดยผู้ดูแล: 28 กันยายน 2011
  2. -jae-
    -jae- New Member Member
    ไม่พลาดคับ:teeth:
  3. Twisty
    Twisty New Member Member
    98
    แล้วเจอกันคร้าบบบบบ
  4. prototype01
    800
    47
    น่าไปจังเลย
  5. Purd_Prostreet2
    Purd_Prostreet2 New Member Member
    316
    เจอกันครับบอล
  6. CHAP_ZA
    CHAP_ZA Member Member
    327
    wowww!!!
  7. ballzwa
    ขอบคุณครับ พี่ปื๊ด
  8. bern_drangkab
    bern_drangkab New Member Member
    535
    จัดไปคร๊าบ อิอิ
  9. G Type R
    3,607
    99
    มาแล้วๆ นึกว่าจะไม่มีซะแล้ว อิอิ
  10. george87
    george87 New Member VIP
    280
    ... งานดีๆมาอีกแล้ว ไปร่วมสนุก ไปร่วมเชียร์ ด้วยคร๊าบบบบบ :teeth::teeth::teeth:
  11. Racing D Project
    283
    เพื่อนงานยุ่งเลยสินะ ของที่ฝากหาให้ด้วยนะคาบบ
  12. ballzwa
    มีสิครับถ้าพี่ๆยังสนับสนุน ผมอยู่ อิอิ
  13. ballzwa
    ขอบคุณครับ พี่จ๊อดรึป่าวครับ
  14. ballzwa
    ได้ขอรับ คุณเพื่อน ไม่มีรถไปวิ่งไปเที่ยวงานเค้าบ้างนะ 555
  15. Taye@YF20
    Taye@YF20 New Member Privilege
    337
    ^^^^ ช่วย Up คร๊าบ ^^^^
  16. george87
    280
    ... ใช่ครับ น้าบอล งานดีๆ ช่วยอัพคร๊าบบบบบบ :teeth:
  17. nung_ek
    nung_ek New Member Member
    116
    สนับสนุนงานดีดีครับน้องบอล
  18. TobZwa Neko
    TobZwa Neko New Member Member
    605
    อ๊ะ...ถูกใจอีกแว้วววว...........
  19. TobZwa Neko
    605
    อัพ
  20. seila4club
    seila4club Active Member Member
    997
    47
  21. น่าไปกาบบบบ
  22. งานใหญ่อีกแล้ว
  23. tokidoki 1.
    tokidoki 1. New Member Member
    230
    ตัวแรงตรึม
  24. meeyai
    meeyai New Member Member
    สนุกแน่ๆครับ
  25. ballzwa
    อัพเดต รุ่นการแข่งขัน แล้วนะครับ
  26. TobZwa Neko
    605
    รับทราบจ้า
  27. Purd_Prostreet2
    316
    บอลครับ ขอกติกาของรุ่น super 2000 CC. หน่อยครับ จะได้เตรียมรถถูกตามกติกาครับ
  28. ผมมันบ้า
    ผมมันบ้า New Member VIP
    80
    รอติดตามชมครับ
  29. ballzwa
    กติการุ่น SUPER 2000 CC
    รุ่น 4 เม็ด 2 หมุน ชิลๆ ( N/A 4 & 2 Rotor )
    ตัวถังรถและแชสซี
    - ต้องเป็นรถยนต์ที่มีจำหน่ายทั่วไปตามท้องตลาด ขับเคลื่อน 2 ล้อ ใช้มิติเดิมของรถ
    - อนุญาตให้เปลี่ยนฝากระโปรงหน้า,หลัง ,บังโคลนหน้า เป็นพลาสติกหรือไฟเบอร์กลาสได้
    - ไม่อนุญาตให้เปลี่ยนกระจกรอบคันเป็นพลาสติกเหนียว (Poly Carbonate )
    - ประตูทุกบานต้องสามารถเปิดจากด้านนอก-ในได้
    - มิติของรถต้องไม่เปลี่ยนแปลงไปจากเดิม
    - แชสซีด้านหน้าและ Fire Wall ต้องเป็นของเดิม
    - ระบบปรับอากาศต้องทำงานได้ตามปกติและต้องมีความเย็น
    - อุปกรณ์ภายในรถต้องมีครบตามมาตรฐานจากโรงงาน
    - กรณีที่มี Roll Cage ภายในรถ อนุโลมให้ไม่ต้องมีเบาะหลัง
    ช่วงล่าง
    - ช่วงล่างหน้าและหลังต้องเป็นจุดยึดเดิมและแบบเดิม แต่อนุญาตให้Up Grade อุปกรณ์ได้
    เครื่องยนต์
    - ต้องเป็นเครื่องยนต์ 4 สูบหรือ 2 Rotor เท่านั้น ไม่จำกัดการModify
    - ขนาดความจุเครื่องยนต์ ไม่เกิน 2000 cc.
    - ห้ามระบบอัดอากาศ
    - ไม่อนุญาตระบบ Nitrous Oxide ( ห้ามมีอุปกรณ์ใดๆติดรถ)
    - ด้านหน้าสุดของเครื่องยนต์ต้องไม่ถอยไปเกินกว่ากึ่งกลางของดุมล้อหน้าและไม่ล้ำเข้าไปในผนัง
    ห้องเครื่องเดิม
    - ห้ามถอดสายพานแอร์ออก
    เกียร์
    - ห้ามการเปลี่ยนเกียร์ด้วยระบบ Air Shifter
    - คันเกียร์ต้องเป็นแบบ H-Pattern เท่านั้น
    - เกียร์ Automatic ต้องเป็นเกียร์เดิมเท่านั้น
    - ระบบ Trip Tronic ต้องมาจากโรงงานควบคู่มากับรถตามรุ่นเท่านั้น
    เชื้อเพลิง
    - อนุญาตให้ใช้เฉพาะ น้ำมัน Gasoline( ไม่จำกัดค่าOctane ) เท่านั้น
    ยาง
    - อนุญาตยาง ทุกชนิด ขนาดไม่เกิน 26 x 10.5 นิ้ว หรือ 275 mm.
    ท่อไอเสีย
    - ปลายท่อต้องหันออกนอกแนวตัวถังทางด้านข้างและด้านหลัง ไอเสียห้ามพ่นลงพื้นอย่างเด็ดขาด
    ความสูงของท่อไอเสียต้องไม่ต่ำกว่า 3” วัดความสูงจากพื้นถนน
    น้ำหนักรถ
    - ไม่ต่ำกว่า 1000 Kg รวมผู้ขับ
  30. ballzwa
    0811014334 เปิดรับสมัครแล้วนะครับ
