How to Reset SRS light
การสนทนาใน 'DAMS' เริ่มโดย Yakumo, 12 มีนาคม 2007
  1. Yakumo
    Yakumo New Member Moderator
    580
    Unplug the SRS wire from the fuse box under the dash.
    Its the one with the yellow plug.
    Take a paper clip and cut it so it is in a U shape.
    Insert into SRS plug.
    Stick key in ignition and turn it to on (don't start the car).
    Within a couple of second the SRS light will turn off.
    Take paper clip off.
    SRS light will come on again.
    Stick paper clip back in quickly.
    Can't remember how many times you need to repeat the above steps so repeat until SRS light blinks twice and turns off.
    __________________
    http://www.geocities.com/myintegra96/srs.html
  2. เปิ้ล MT
    เปิ้ล MT New Member Member
    39
    ผมทำแล้ว ไม่ได้อ่ะ ครับ.
    อิๆๆๆ รถ ผมไม่มีถุงลม อ่า....
  3. Piisorn_es
    Piisorn_es New Member Member
    176
    :cool: Thanks You Yakumo :cool:
