RacingWeb Community
Racing Forum (Cars Forum)
2008_AstonMartin_V8VantageGT2
<p>[QUOTE="corona ตัวน้อย, post: 1255552, member: 1543"]<img src="styles/default/xenforo/clear.png" class="mceSmilieSprite mceSmilie1" alt=":)" unselectable="on" unselectable="on" /> โหดีจัง<img src="styles/default/xenforo/clear.png" class="mceSmilieSprite mceSmilie1" alt=":)" unselectable="on" unselectable="on" /></p><p><br /></p><p>engine   V8 w/Dry Sump Lubrication </p><p>position   Front Longituidnal </p><p>valvetrain   4 Valves per Cyl w/Variable Inlet Camshaft Timing </p><p>displacement   4280 cc / 261.2 in&sup3; </p><p>bore   89 mm / 3.5 in </p><p>stroke   86 mm / 3.39 in </p><p>power   283.4 kw / Not Available bhp </p><p>body / frame   Aluminium Alloy, Steel, Composite & Magnesium Alloy Body over Bonded   Aluminium Structure  </p><p>driven wheels   RWD w/Traction Control </p><p>front brakes   Ventilated & Grooved Discs w/4-Piston Brembro Calipers </p><p>f brake   size x 355 mm / x 14.0 in </p><p>rear brakes   Ventilated & Grooved Discs w/4-Piston Brembro Calipers </p><p>r brake   size x 330 mm / x 13.0 in </p><p>steering   Rack & Pinion w/Power Assist </p><p>f suspension   Double Aluminium Wishbones w/Coil Over Monotube Dampers, Anti-Roll Bar </p><p>r suspension   Double Aluminium Wishbones w/Coil Over Monotube Dampers, Anti-Roll Bar </p><p>weight   1570 kg / 3461 lbs </p><p>wheelbase   2600 mm / 102.4 in </p><p>front track   1568 mm / 61.7 in </p><p>rear track   1562 mm / 61.5 in </p><p>length   4683 mm / 184.4 in </p><p>width   1866 mm / 73.5 in </p><p>heigh  t 1255 mm / 49.4 in </p><p>gear ratios   :1 </p><p>final drive Not AvailableNot Available:1[/QUOTE]</p><p><br /></p>
[QUOTE="corona ตัวน้อย, post: 1255552, member: 1543"]:) โหดีจัง:) engine V8 w/Dry Sump Lubrication position Front Longituidnal valvetrain 4 Valves per Cyl w/Variable Inlet Camshaft Timing displacement 4280 cc / 261.2 in³ bore 89 mm / 3.5 in stroke 86 mm / 3.39 in power 283.4 kw / Not Available bhp body / frame Aluminium Alloy, Steel, Composite & Magnesium Alloy Body over Bonded Aluminium Structure driven wheels RWD w/Traction Control front brakes Ventilated & Grooved Discs w/4-Piston Brembro Calipers f brake size x 355 mm / x 14.0 in rear brakes Ventilated & Grooved Discs w/4-Piston Brembro Calipers r brake size x 330 mm / x 13.0 in steering Rack & Pinion w/Power Assist f suspension Double Aluminium Wishbones w/Coil Over Monotube Dampers, Anti-Roll Bar r suspension Double Aluminium Wishbones w/Coil Over Monotube Dampers, Anti-Roll Bar weight 1570 kg / 3461 lbs wheelbase 2600 mm / 102.4 in front track 1568 mm / 61.7 in rear track 1562 mm / 61.5 in length 4683 mm / 184.4 in width 1866 mm / 73.5 in heigh t 1255 mm / 49.4 in gear ratios :1 final drive Not AvailableNot Available:1[/QUOTE]
RacingWeb Community
