วิธีใช้ over drive
การสนทนาใน 'Sunny Thailand' เริ่มโดย bee15, 1 มีนาคม 2009
  1. bee15
    bee15 New Member Member
    309
    57
    ?ҡ˹ѧ????ҹ¹?? ???? 388 ??Ш???͹ ?ѹ??¹ 2541
    ???????¨?ԧ ? ?ͧ????? ?Overdrive Ratio? ??? .?ѵ?ҷ???ͧ?????????????ҡ?ҧ??ع?????ǡ?????ҢѺ???????ͧ????? ?֧??????????ͧ????ͧ???ŧ???ö??????Ǣ?? ??觵?????????¹???ͨж??????? ?ǡ??ͧ??????????ѵ?ҷ???ӡ??? 1 ?????????? Overdrive ??ǹ?ŧҹ?ͧ?ѹ???????ҧ?? ????ҡ???¢?Ҵ?˹ ??е?ͧ???????Ѻ???ѧ????ͧ ?ѵ?ҷ???ͧ????????ͺǧ?ҧ ???˹ѡ????ٻ?ç?ͧö??Сͺ?ѹ
    ?ش???ʧ????ѡ?ͧ?????ҹ???????????????? ??? ????Ŵ?ͺ????ͧ¹?????ӧҹ????ŧ??????????ѵ?ҷ?????????͢Ѻ????͹???¤??????Ƿ????ҡѹ ?????繡??Ŵ?????֡?????????ѵ????????ͧ??????ԧ????ŧ???ҧ?? ?????? 4 ??????ѵ?ҷ?????? 1.000 ???????觴??¤??????? 100 ??./??. ?????ͺ????ͧ 3,400 ?ͺ??͹ҷ? ?????????? 5 ??????ѵ?ҷ???§ 0.850 ?????????? 100 ??./??. ??ҡѹ ???Ҩ?????ͺ????ͧö¹????§?? 2,800 ?ͺ??͹ҷ? ?????ա???֡????????????ͧ??????ԧ???¡???????ͧ¹????ӧҹ 3,400 ?ͺ??͹ҷ????????¶֧?????Ҩе?ͧ??觴??¤??????Ǥ???????ж???ա?????᫧???????¹?ŧ???????Ǻ??? ? ???????????͹?ѹ???????? 5 ???? ??????????????????????ҧ?????????Ѵ???????? ???ͧ?ҡ????? 5 ?????ѵ????觹??¡???????? 4 ?ѧ?????????ա?? ??????᫧???Ѻ?֧??ͧ???ѹ????֡??????йҹ???????????¡?ç????ç?Դ?͡????ҹ ????͹?Ѻ?͹?͡ö??觶???͡????????? 1 ???ѹ????? ? ???͡?????????? ????????¹???͡??Ǵ???????? 3 ??е?ͧ???ѹ????֡???????????? 3 ??????ѵ?ҷ???ӡ???????? 1 㹤?????????ҡѹ?????ͺ????ͧ???¡??? ?????͡ö????????? 3 ?ѹ?????Ŵ????֡?????????????????Ѵ ????͡Ѻ????͡ö????????? 1 ???
    ?????˵ع???ҡ?Դ????????? Over drive ????????ª???ԧ ? ??е?ͧ??????? ????????١?Ըմ???
    ?????١?Ը?
    㹡????????? Overdrive ?????????????? ??С???á??͵?ͧ?????????????Ѻʶҹ??ó??????Ҿ??è?Ҩ? ???ҧ?? ??âѺ???????ͧ???????????ǵ?? ?ա??????????ش???? ? Ẻ???????????ǵ?? ?ա??????????ش???? ? Ẻ?????????? ???????????ѵ??ѵԷ???ջ????Դ-?Դ ?????ѧ??? OD off ????з???ͷҧ??? ????ö????????????Թ???? 60-80 ??./??. (???????Ѻ???ѧ????ͧ¹??) ?֧???¡???Ƿ?? OD on ????????????????¹?? Overdrive
    ?ǡö??????ѵ??ѵԷ????????? Over drive ?о?????????㹵??˹???????٧?ش??ҷ???????ö ö?ҧ??蹹?鹢?Ҵ??ҹ???¤??????? 40 ??./??. ?ѧ??????????¹???????????¡??? Ẻ???͡?ҡ??????ç?Դ???ͧ??????ԧ?ҡ??? ᷹?????Դ?????????Ѵ?????????????? ???;ǡö?????????? ???????????? Overdrive 㹡?âѺ???????????ǵ???ҡ ? ??????ռ?੾???ѵ????觡Ѻ?ѵ????????ͧ??ҹ?? ?ѧ?????ش?Ѻ????͹????к??觡??ѧ??ʹ??????ͧ¹???Դ???ش??????????ա????
    ??㹡??᫧
    ????͢Ѻ????㹪?ǧ???????ǻ???ҳ 60-100 ??./??. ?¢Ѻ????͹????㹨ѧ???????? Overdrive ????դ?????ͧ???᫧ö?ѹ??ҧ˹??Ẻ????պ??????觴????????ҡ?ѡ ??á???Է???? OD off ????????¹?????ŧ??????????ӡ?͹ ???ǡ??ѹ??? (?? ? ) ???????ѧ????ͧ᫧???? ?;???????????????????Ǩ֧???¡???Է??????¹??Ѻ???? OD on ?????? ?Ըչ????Ǵ??????л????Ѵ???ҡ?????᫧??? ? ????ѧ?????????? Overdrive ??觨??״?Ҵ??????㹡??᫧?ҹ???? ?Ըչ??з??????᫧ ???????Ŕ ???ҡ?á??ѹ????֡???????? Kick Down ????¹??Ѻ????????? ???С?äԡ??ǹ???????ͧ¹??????ͺ?٧ ?ѵ??????ع?ç??Ъҡ??Ъ???Թ???????? ??觡?й????????֡????????????ͧ??????ԧ?????һ???ª?? (?ա????)
    ???????????㹷??Ѻ?ѹ
    ?ǡ????? Overdrive ???ѵ?ҷ???????? ?????????ͧ¹????????͹????ä ?ѧ???㹡???á?????????á??ǡ??һ??Դ????˵ع?????ͤ?????ʹ?????Ъ????????????㹡???á???ŧ ???ҷ??Ѻö㹨ش?Ѻ?ѹ ?? ?Ѻŧ?ҧ?Ҵ ŧ?оҹ ????????㹨ش?ʹ?????繷ҧ??ҧ˹?? ??è?????¹??Ѻ??????????? ?¡???Է???繵??˹? OD off ?ѵ????????ͧ??????ԧ?Ҩ????????ա???????Ժ????Ժ?ѧ?? ??????֡??º?Ѻ??ҫ???ö???ͧ?ҡ??СԴ??鹷??¤ѹ??????Ǩ?????֡???Ҥ??????ҡѹ???? ??੾??ö??????к??ä ABS ??觻????????á?????ǡ???ö???????? ABS ???????? ?Ҽ???ç?Ѻ?ѧ????????????????????ա???仡ѹ?˭? ?ä?ѹ?????·ѹ 㹺ҧ??????Ҩ֧??á???Է???? OD off ???Ŵŧ????????????????? ??͹????ä? ?Ҫ???Ŵ???????Ǣͧö?????ա?ҧ˹??
    ?ӹͧ???ǡѹ???ҢѺö???駴??¤??????? ?????ҡ???Է???? OD off Ŵ?????ŧ ???Դ
    ?͹????ä????????÷ç??Ǣͧö?բ?? ???ҧ???????????ҡ???? ?ա???????ö???????ͧ?ҵ??ö?͡?ҡ?????Ǵ???ǡ????ա???? ???Ŵ?????ŧ?Ҩ?????????ʹ??????˹?͡??? ?????ҡ????˵ءзѹ?ѹ??ҧ?駡??????ö?á????ö???????觺ѧ?Ѻ?Ǻ???ö????¢??
  2. NGO113
    NGO113 New Member Member
    1,230
    106
    แหล่ม ครับ สาระดี ๆ
    ผม รู้ แต่ ว่า
    ปุ่ม นี้ ใช้ สำหรับ ปิด เกียร์ สี่ ของ ออโต้ ครับ
    โดย ปกติ จะ เปิด อยู่
    ถ้า กด จะ ปิด เกียร์ สี่ครับ
  3. Step-Divinity
    3,737
    590
    เปิดไว้ตลอดไปโลด เชื่อสิ
  4. jojo9
    jojo9 New Member Member
    3,938
    658
    มีสาระนะเนี่ยยยยย...
  5. อาบัง
    อาบัง New Member Member
    700
    448
    เข้ามาหาความรู้ครับ
  6. OaTT_B14
    OaTT_B14 New Member Member
    4,399
    692
    เกียร์ออโต้ คืออะไร ไม่รู้จัก ขับไม่เป็น:D:D:D:D:D
  7. bee15
    309
    57
    ไม่เป็นไรคับ มีสาระอะไรดีๆที่พอจะแบ่งปันกันผมยินดีเสมอสำหรับชาว Sunny-thailand เพราะผมก็ได้อะไรดีๆใน Sunny-thailand เหมือนกัน
  8. Addsan
    Addsan Member Member
    37
    ความรู้ครับ
  9. โบตั๋นน้อย
    โบตั๋นน้อย New Member Member
    3,588
    411
    ลืมสมัยกะปิยังเป็น ออโต้ สปริงตัด แล้วเหรอ ตะเอง:D :D :D
  10. NGO113
    1,230
    106
    พี่เบิ้ม เค้า ยัง ไม่รู้จัก เลยคำว่า เกียร์มัว
    อิอิอิ
    อ้างอิงหน่อยนะ พี่เบิ้ม ม่ะว่า กัน
