Diagram Air Auto Accord 88-89 A1 Yellow/Black IG - Ignition A2 Red ILL - Illumination...
การสนทนาใน 'Accord 88-89 Club' เริ่มโดย ณัฐพล สุวรรณปัญญา, 13 มกราคม 2012
    Diagram Air Auto Accord 88-89 A1 Yellow/Black IG - Ignition A2 Red ILL - Illumination A3 White/Yellow +B - Constant power A4 N/A INSW A5 Light Green/Black BLW - 3 pin connector with a fat blue/black wire A6 N/A INM A7 Grey S5 - Light sensor (on top of gauges) & Temperature control motor A8 Blue/Black MV - The fat Blue/Black wires A9 A10 Black GND - Ground A11 Black SG - Second Ground A12 Light Blue TW - goes into this funny thing inside the heater core, it has a orange wire A13 Grey/Black TR - Center console fan A14 Pink TAM - Outside Temperature Sensor A15 Orange ST - Light sensor (the one on top of teh gauges) A16 Brown TE - A/C thermometer thing in that A/C radiator box A17 Green/White AP - Temperature control motor A18 Green/Yellow MP - the motor that decides the face/feet/defrost (5 pins) B1 Red/Black NS - Park Lights B2 Green SM - Centre Console Fan B3 Yellow/Red REC - REC/FRESH Motor B4 Blue/Red MGC - A/C pressure switch? B5 N/A F/R B6 Orange/White FR - Blue Relay Plug B7 Yellow/Blue FRS - REC/FRESH Motor B8 B9 Red/Yellow HOT - Temperature control motor B10 Red/White COL - Temperature control motor B11 Blue/White DEF - the motor that decides the face/feet/defrost (5 pins) B12 Red/Green VEN - the motor that decides the face/feet/defrost (5 pins)
  1. ผมหามาจากอเมริกาเลยนะเนี่ยคราวนี้ต่อได้ชัวๆแอร์ออโต้
  2. ขอตู้ดดดด นะแ
