e36 ///M3 turbo wide body
การสนทนาใน 'E36 Club' เริ่มโดย 9K3Series, 17 เมษายน 2008
  1. 9K3Series
    9K3Series New Member Member
    ???ʴջ??????¤?Ѻ ????дԶբ???ѡ??Ҵ?????駷? ????? e36 ???? ?ҽҡ?ա?ѹ??Ѻ ??? :)
    Turbo System
    ? T4 0.68 a/r pt67p-trim dbb turbo for street
    ? T4 0.81 a/r pt76gts turbo for strip
    ? Custom SFR 1 5/8' 321SS tubular T4 exhaust manifold
    ? Custom SFR aluminum intake manifold
    ? 80mm Accufab throttle body
    ? Lokar throttle cable
    ? Custom SFR 3' downpipe ALL V-BAND
    ? Custom SFR Intercooler w/Spearco cores
    ? Custom SFR charge piping
    ? Custom SFR polished 3' intercooler piping ALL V-BAND
    ? 60mm NewGen Turbonetics external wastegate
    ? 50mm Turbonetics Godzilla BOV
    Exhaust System
    ? 3.5' pipe
    ? All Burns 304ss piping
    ? All v-band clamps
    ? Magnaflow muffler with 3.5' turn-down for stealthness
    Engine Block Mods
    ? Magnafluxed '92 m50 non-vanos block
    ? Ballanced engine assembly
    ? Forged 84mm stroke crank
    ? Polish crankshaft journals-main and rod
    ? MLS head gasket 0.070
    ? Double offset O-rings
    ? 8.5:1 Custom JE forged pistons (over 84mm)
    ? Total seal rings
    ? Custom Pauter forged rods
    ? ARP main studs
    ? New oil pump
    ? Line bore-deck-bore
    ? ARP rod bolts
    ? Resurface block
    ? Complete engine re-seal & paint
    ? New BMW pulleys and small parts
    Cylinder Head Mods
    ? Clean m52 vanos head
    ? Resurface Head
    ? Complete valve job (pressure test before and after)
    ? Ferrea Ti retainers
    ? Ferrea keepers
    ? Ferrea dual valve springs
    ? New valve guides
    ? m52 vanos cams
    ? ARP head studs
    ? Pressure test
    ? Clean matting surface
    ? New valve seats
    ? New complete gasket kit
    Brand New BMW Replaced Engine Parts
    ? Valve guides
    ? Main bearing set
    ? Rod bearing set
    ? Waterpump
    ? Chain tension
    ? Timing chain
    ? Thermostat
    ? Hydraulic valve lifters
    ? Timing chain rail
    ? Oil pump
    ? Chain sprocket
    ? Top-end reseal kit
    Tuning & Fuel
    ? Sias Tuning PnP Electromotive Tec 3R ECU
    ? PLX wideband
    ? Weldon FPR
    ? Liquid filled pressure gauge
    ? Greddy Profec B Boost Controller
    ? Manual Boost Controller (use whichever you want, I like the MBC better)
    ? Dual in-tank Walboro 255LPH fuel pumps
    ? Steel braided AN10 fuel lines
    ? Custom SFR billet fuel rail
    ? 1200cc injectors
    Under Hood Bling
    ? Wrinkle black powdercoating finish on SFR custom engine cover
    ? Wrinkle black powdercoating finish on SFR custom charge pipe to TB
    ? Wrinkle black powdercoating finish on SFR custom engine hoist connector
    ? SFR custom hard lines for water cooling of turbo
    ? SFR custom hard lines for A/C
    ? SFR custom -12 AN fitting off crank case vent with steel braided line
    ? AN fittings with steel braided lines for fuel
    ? AN fittings with steel braided lines for turbo oil drain
    ? SFR custom Billet reservoir tank for radiator overfill
    ? SFR custom Billet reservoir tank for power steering
    ? SFR custom polished fan shroud
    ? Griffin radiator with SFR custom end tanks
    Suspension Mods
    ? Eibach Sway Bars
    ? H&R Coilovers
    ? Carbon Fiber Front Strut Bar
    ? Powerflex RTABs
    ? Powerflex LCABs
    ? OEM X-brace
    ? Vorshlag Engine Mounts
    ? UUC red-top tranny mounts
    ? GC RSMs
    ? GC RCCAs
    Drivetrain Mods
    ? Driveshaft Shop 1000hp driveshaft w/ aluminum guibo
    ? Driveshaft Shop 1000hp half shafts
    ? SFR custom tranny ear TIG reinforcement
    ? Mike Radowski reinforced tranny brace
    ? AA Differential Bolt Brace
    ? 3.23 LSD
    Exterior Mods
    ? Custom widebody kit (e30 m3 style with e36 flare)
    ? Door handles Painted Silver To Match Car
    ? ZKW's With DDE Lightning Enhanced
    ? 6000K HIDs
    ? Clear Corners All Around With Blue Superwhite Bulbs
    ? Steel Braided Brake Lines
    ? 14' Cross drilled Stoptech (front) brakes
    ? 13' Cross drilled Stoptech (rear) brakes
    ? Hood scoops
    ? Washer Fluid Squirters Deleted
    ? 18x12 rear 18x10 front CCW SP500 rims
    ? Super rare BBS RS deep dish 18' rims set as well all custom except centers ($8000 value)
    ? 315x35x18 BFG Drag Radials rear (equivalent to 335 street radials)
    ? 265x35x18 BFG street radials
    Interior Mods
    ? MOMO Steering Wheel
    ? Vader ///M3 Recaro Seats
    ? ACS Aluminum Pedals
    ? Defi Display Unit for oil temp, oil press, water temp, speed, fuel press
    ? Defi Control Unit For Datalogging Gauges
    ? Zender Aluminum E-Brake Handle
    ? SFR Custom AEM AFR wideband gauge pod on steering column
    ? SFR custom carbon fiber panel with headlight control relocation, Defi Controller location and EBC location
    ? Defi BF Boost gauge in location of headlight switch
    ? Rogue SSK
    Stereo Mods
    ? Kenwood Touch Screen DVD
    ? Kenwood 10-Disk CD Changer
    ? Sony Playstation 2
    ? 6 Boston Accoustic Mids & Highs
    ? 1 4-Channel 1000 Watt Amp - Fusion
    ? Clifford 7000 Alarm
    ? 2 2500 Watt Fusion Amps (Jonah Lomu)
    ? Large Cap
    ? 4 JL 10w3v2 Subs
    ? Custom Enclosure With Molded Fiberglass Painted To Match Car
    source: http://cgi.ebay.com/ebaymotors/ws/e...m=160230497976&ssPageName=STRK:MEWA:IT&ih=006
    NEXTWEEK ถูกใจสิ่งนี้
  2. HURRICANE
    HURRICANE New Member Member
    634
  3. NEXTWEEK
    NEXTWEEK New Member Privilege
    6,438
    995
    ชอบ ๆๆๆๆ
  4. G.@.l.f. e36
    G.@.l.f. e36 New Member Member
    336
  5. Nick
    Nick New Member Member
    433
    อย่างโหดดดดดดดดดดดดดดดด
  6. Nick
    433
    หวัดดีครับ พี่กาน :D
  7. BiG FaT
    BiG FaT New Member Member
    510
    เห็นเฮดเดอร์แล้วงงแบบว่ายั้วเยี้ยมาก
  8. Evil_CaTz
    Evil_CaTz New Member VIP
    256
    ชอบคุณมากๆ คับสำหรับรูปสวยๆ :D:D:D
  9. Fool again
    Fool again New Member Member
    281
    สุด สุด ไป เลย ลูก พี่
  10. lovekodomo
    lovekodomo New Member Member
    661
    สวยดีอ่า อิอิ
  11. P@E
    P@E New Member Member
    561
    LOVE E36 ค๊าบ...บ
  12. JZA80 HKS
    JZA80 HKS New Member Privilege
    173
    สวยสุดยอดเลยครับ
    ขอบคุณที่เอามาให้ชมครับ
  13. autonice
    autonice New Member VIP
    276
    เจ๋งๆๆ มะมากไ
  14. aunn_fit
    aunn_fit New Member Member
    387
    upๆๆๆๆๆๆๆๆๆๆๆๆๆๆๆๆๆๆๆๆๆๆๆๆๆๆๆๆๆ
  15. lovekodomo
    661
  16. สวยคับ แต่ว่าโป่งมันทำไมออกมาเยอะมาก โหดโคตร
  17. jigko_london
    jigko_london New Member Member
    629
    สวย งาม มากคับ
  18. T.Race
    T.Race New Member Member
    259
    มันยัดลง ไปได้ไง แน่นขนาดนั้น เก่งจิงๆ
